Hi Corey,
Yes that is basically correct. KFlop by itself actually has 46 Digital I/O lines (labeled IO0 through IO45). All can be used as General Purpose I/O but some pins have dedicated hardware functions. Step/Dir output pins, PWM output pins, and quadrature encoder input pins are dedicated. Home, Limits, Index Pulses, or other I/O are handled through software so they may be connected to any available input. Some inputs are +5V tolerant and some are only +3.3V tolerant. When option boards are attached (Kanalog or SnapAmps), then certain KFlop connectors are consumed but with additional I/O added from the option boards. Steppers and Servos can require variable number of I/O bits depending on the type and options (ie. usually servos do not use Step/Dir outputs). I wish it was simpler.
I hope this helps.
Message: 499 |
Date: 7/2/2010 |
| Subject: Re: General question about capabilities of Kflop |
Thanks Tom, that helps a lot. You may want to consider making this more obvious on your website and also on the Artsoft plugins page. http://www.machsupport.com/plugins.php
I don't think that either location is doing justice to the capabilities of this board. cheers, c On Fri, Jul 2, 2010 at 12:59 PM, Tom Kerekes <tk@...> wrote:
Hi Corey,
I hope this helps.
Message: 500 |
Date: 7/2/2010 |
Looks like Tom answered you and confirmed our suspicions about the number of I/O
Damn its hot outside....I got the mill loaded on the trailer and ready to go. It went pretty well. We've taken a few pictures. I'll post them over the weekend.
Did I say its friggin HOT outside?
Marty
---- Corey Renner < vandal968@...> wrote:
> Marty,
> I've seen that page, but it still leaves me with questions.
> If I'm reading this right, it looks like the board has 45 general purpose
> I/O lines. If I am using 5 axis running steppers (no feedback), that should
> use 10 lines. So I believe that I would have 35 I/O lines left that could
> be used for anything under Mach3, I'm just not positive if this is the
> case. If this is true, Dynomotion should make it OBVIOUS on their web-site
> since this would be quite a selling point.
> I'd like to see something like this on their website:
> 45 available I/O's
> Steppers use 2 per axis, Servos use 4 per axis, all remaining can be used
> for any purpose:
> Examples:
> 3-axis stepper with 39 I/O's available.
> 3-axis servo with 33 I/O's available
> 5-axis stepper with 35 I/O's available
> 5-axis servo with 25 I/O's available.
> Is what I wrote above true or not? I still don't have an answer. Potential
> customers with unanswered questions are lost sales.
> c
> On Fri, Jul 2, 2010 at 10:38 AM, Marty Escarcega <escarcega@...> wrote:
> > Corey, had you had a look at this page:
> > http://dynomotion.com/Help/SchematicsKFLOP/ConnectorsKFLOP.htm
> > ---- Corey Renner <vandal968@...> wrote:
> > > Bengt,
> > > Two outputs for spindle because it's Off/Enable FWD/Enable REV. I'm not
> > > following how all the limits and homes can be handled on two inputs, can
> > you
> > > elaborate? I know that I can combine all the limits on one input since
> > it
> > > doesn't really matter which one trips. Are you suggesting doing
> > something
> > > similar on the home switches as well? My limits are cherry switches, but
> > my
> > > home switches are inductive prox.
> > > I'd still like to know the maximum number of digital ins and digital outs
> > on
> > > the Kflop board.
> > > cheers,
> > > c
> > > On Fri, Jul 2, 2010 at 7:32 AM, Bengt Sjoelund <cnc@...>
> > wrote:
> > > > Hi Corey,
> > > > Why 2 outputs for spindle?
> > > > ~9 outputs (2 spindle, 1 coolant, 6 air solenoids, etc.)
> > > > + and - limits and home needs max 3 inputs do it with 2 inputs
> > > > ~19 inputs (6 limit switches, 3 home switches, 7 ATC feedback, 3
> > physical
> > > > buttons)
> > > > Cheers Bengt
> > Yahoo! Groups Links
Message: 501 |
Date: 7/2/2010 |
Meant to send this directly to Corey, but FWIW, we live in the Phoenix Metropolitan area and are part of the same metalworking club. At 4:15pm its 112 degrees.....I'm bringing home a 10x54 CNC Knee mill tomorrow, moving it myself.
Marty
> Marty
> > Marty,
> > 45 available I/O's
> > for any purpose:
> > Examples:
> > c
> > > > Bengt,
> > > you
> > > it
> > > something
> > > my
> > > on
> > > > the Kflop board.
> > > > cheers,
> > > > c
> > > wrote:
> > > > > Hi Corey,
> > > physical
> > > > > buttons)
> > > > > Cheers Bengt
> > > Yahoo! Groups Links
> Yahoo! Groups Links
